2 members (homer52, Tronman), 239 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#36008 06/02/2002 2:20 AM
thrust bearing arm for a 4 speed crash box it goes on a 235 engine can the arms be adjusted so i can get some clutch play on the pedal im having problems ive replaced the clutch and now have no free play theres 2 hooks that join with 2 nuts but with these are screwed up to the max i hope the arm can be adjusted cause there is limited movement
p j a
The threaded piece that fits into the hole of the clutch arm should have one or two nuts that are for adjustment purposes.
Yeah! like Mech said, two big nuts on that L-shaped link rod just before the clutch arm. I put a new clutch in my 54 2-ton and it made noises when I put it to floor, quit when raised up some. Wouldn't shift w/out noise all the way down, but worked OK off the floor about 1". I had to take pedal and add more play to get it to quit making noise and worked good for last year now.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
