2 members (78buckshot, IHPWR),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36000 03/02/2005 5:01 AM | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | I took my truck on a 20 mile drive the other day down to the body shop. After i got off the freeway and pulled in i backed up and the chatter was so bad i almost got whiplash. I pulled forward and it did it as well, but is way worse in reverse. I dont notice it much when i just drive it on short drives. Do you think a long drive could cause this? Clutch not adjusted properly and is slipping on the freeway? I would think if it was slipping for 20 miles it would be so burnt or glazed that it wouldnt work at all. Any insight on this? thanks | | |
