1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#357871 01/08/2008 4:17 AM
Hello bolter`s,
Bought a new bed with no hole`s drilled in bedsides,front panel and rear cross sill.Can anybody help with location,dimension of hole`s and bolt size? Any help will be appreciated.Thank`s
willis40 #358011 01/08/2008 4:33 PM
Are you still using original cross sills under the bed ? If so, holes in rear cross sill will need to line up with existing. If not, becomes a function of how many planks you plan on using across the bed. Bed strips bolt down thru the gap between the planks, and into the cross sills. Holes in front panel flange are centered on the planks. Holes on bed side flanges need to bolt thru ends of cross sills for support. I can send you pics of my '40, but it isn't entirely stock.
1940 Chevy KC 1/2-Ton
Britcon #359660 01/12/2008 2:12 AM
I`m going to be using original cross sill if possible.The bed wood is not the problem.I`m talking were front panel bolts to bedsides and rear cross sill bolts to bedsides.The truck will have a 396 /400 and 12 bolt rearend,22 wide rear tires.I`m going to need all the help i can get.You can send pics. Thanks
willis40 #360149 01/13/2008 7:04 AM
Send me your email.I will snap some pics of my bed - see if it might help.
Britcon #360355 01/13/2008 10:57 PM
My e-mail is [email protected] Thank`s for helping.
willis40 #360666 01/14/2008 7:44 PM
If you haven't already done so, have a look at Mar-K website. They have a lot of good info there as well.
Britcon #360691 01/14/2008 9:29 PM
Thanks for the plug britcon, but there may not be much on the site that can help him with this one.
The front bed panel is the same from 40-45 so if you know someone with one you can get a pattern from them.
There are 4 bolts on each side of the front bed panel. All 1/4"-20 X 5/8" hex head bolts. The front bed panel also uses a long threaded rod that attaches through the top curl to each bed side. We sell a threaded rod and hardware kit for this.
The rear cross sill is also the same from 40-45. You will use 4 bolts on each side of the rear cross sill that are 5/16"-18 X 3/4" at the bottom of the rear cross sill and bed sides. Then you will need 2 more on each side to hold on the hinges. We sell a hardware kit for this as well.
It will be difficult for you if those bed sides are not prepunched, as at least one of these holes is nearly impossible to reach to put a nut on.
When we make these parts, all the holes are punched in the correct locations and there are welded nuts in the areas that are impossible to reach.
