7 members (32Fordpuchoptop, Nhluvstruck, 1955 1 Series, Steve 210, DHedrick, Bill Hanlon, 1 invisible), 153 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
Apprentice
Apprentice
I'm not currently having any electrical problems but I mentioned changing from 6v to 12v to a tractor buff I know. He said there are ways to adjust certain 6v generators to give 8 or 10 volts. He said he's done this several times on tractors and says the coil will run hot but hasn't burned any up yet. Does this sound possible? What else would you change, voltage regulator? What advantage is there to doing this?
Ex Hall Monitor
Ex Hall Monitor
I can think of no advantage. Getting 8 volts would be no problem, just adjust the output at the regulator. I've never tried to get 10 volts so can't speak to that. Sounds like a bandaid "fix" for a larger problem to me. ohwell
From experience I can tell you that if your going to start upgrading from 6 volt, then go all the way to 12 and enjoy the difference in cranking power, 12 volt battery availabilty, 12 volt regulator availability that doesnt have to be tampered with etc, etc. You can still keep original apperance of the starting and cranking system if done correct. IM me if you would like more info on how this works.
Ken
