| | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35883 01/03/2004 1:25 PM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Okay guys I know this may be viewed as a dumb butt question, but how do you remove the draft tube from the engine. The only reference my manual makes to it is that it should be removed and cleaned. I getting ready to send block to shop for prep. I was under the imprssion that it just pushed into hole and the bracket bolt at the oil pan held in place (I have removed the bolt). I have soaked the crap out it with rust remover -- it stil doesn't budge. PLEASE HELP. Thanks | | |
#35884 01/05/2004 10:52 PM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | I just pulled mine out last weekend and "cleaned" and repainted it. You are correct. Once you remove the bolt down by the pan it should pull out. I used rust remover and penetrating oil on mine, but it eventually needed some tapping by my "persuader" before she budged. I'm righted handed so adjust accordingly. :-) Using my left hand I put constant upwards pressure on the tube (in other words I pulled like heck) while tapping the tube with my hammer. I started tapping at 12 O'clock, then moved to three, then six, then nine, then back to 12. It was stubborn but eventually I got her to rock loose. To clean it, I used an old farmer's/garage mechanic trick. I filled it with lamp oil and then set her on fire. She burned really slow and smokey for quite awhile. I then rinsed her out with gas, and then lit her again. For the coup de gras I sprayed her with a degreaser, washed her with soap, sanded her slightly and primed and painted her. She looks beauuutifull!
Hope this helps!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
#35885 01/05/2004 10:57 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Since you are sending the block off, drop the oil pan and drive it out from the inside.
Fred 52 3600 69 C-10
