| | | Forums66 Topics128,212 Posts1,057,463 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Hi All,
I have been reading Chilton Repair Manual in my spare time and have a question that has always bugged me:
What is the definition of a "turn" in degrees?
Is one full turn 360 degrees or 180? Half a turn 180 degrees or 90? A quarter turn 90 degrees or 45?
For instance, in setting the idle speed on a Rochester BV carb, "Turn the idle screw slightly to seat, and then back out 1 1/2 turns" ... "adjust the mixture screw to obtain a 20 rpm drop, then back out screw 1/4 turn". On hydraulic valves, "when all play has been removed, turn the adjusting nut in 1 full turn"
When I turn a screwdriver, wrench or ratchet I consider one physical turn equal to 180 degrees. Am I totally offbase on this? Any input? Am I thinking too hard on this subject? Thanks!
JC in KC "The future will be better tomorrow." Dan Quayle 1965 Chevy C10 Long Fleetside
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 1 full turn would be 360 degrees.
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | Think of that screw having a mark on one side. Turn it 180 degrees and the mark will now be on the opposite side of where it started. So, in order to get a full turn, 360 degrees, you have to start from where the mark is and bring it around fully to end where it began. One full turn. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | This is math. 180 is a line. Think of 360 as a full circle. | | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Thanks for all the input. I've done a lot of math in my time and also a lot of survey work dealing with degrees, radians, azimuths etc., but never seen any reference to a "turn" vs. degrees. Thanks for clarifying this.
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | "Dude! He did, like, a total 360 and got pointed the other way."
Oh no, he didn't. Why do they keep saying that?
Last edited by hotshoe36; 01/13/2008 3:25 AM. Reason: none, really. Just mean-spiritedness, if that is a word.
1951 3800 Be the change you want to see. -hotshoe
