7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible), 105 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#358693 01/10/2008 1:26 AM
Does anyone know a good way to remove the black tar coating on the ceiling of the cab? Apparantly it was used to adhear insulation-sound deadener. thanks, Jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
I used one of those citrus based cleaners, forget the name, found it at a local farm store. It worked fairly well. I would suppose that brake or carb cleaner would work, too.
For putting in the new one, 3M Super 777 spray adheasive works extremely well.
Bill Burmeister
I agree with everything Bill suggest above.
You could also try any paint remover, perhaps applied AFTER you heat up the tar-surface with a heat gun.
That tar/adhesive is extremely difficult to remove.
Tim
I wouldn't bother removing it unless the top of your cab is rusting out. It keeps condensation from forming under the headliner.
Paint & Body Shop moderator
Unless you plan on repainting it, leave it. If you chose to heat and scrape, be careful or you may be painting it to cover gouge marks from scraping.
Hank
1951 restoration on website
http://www.hanklong.com
I agree, why remove it? If anything it is somewhat useful as a sound deadener and like 4ontheFloor it resists moisture.
~Jim
I sure don't want to make any more work for myself, but I have a ton of dents in the roof. I thought it would be better to remove the tar before I started with hammer and dolly.
I would try hammering the dents out with the tar attached. If it works you haven't made extra work, if not well...
~Jim
The dolly will most likely get gummed up. If the cab is gutted you could try an oven cleaner, such as Mr. Muscle, to soften tar up. It's some pretty nasty stuff so gloves,face and nose protection is needed. Spray it on, scrape or power wash off. Good luck
Dan
Dave Giorgi
Unregistered
Dave Giorgi
Unregistered
Laquer Thinner in a spray bottle with a scraper works well. Be sure it is well ventilated and go easy with the scraper.
Dave
