2 members (NJC, 1 invisible), 109 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#358433 01/09/2008 3:18 PM
U
U Offline
Just wondering; are the valve springs heavier on the 261 motor?
uncleb #358442 01/09/2008 3:46 PM
In 1954, the first year of the 261 engine, "Higher load inlet and exhaust valve springs required by the higher valve lift were used [compared to the Loadmaster 235]. . . More rigid valve rocker arms and larger diameter push rods are used to minimized valve train flexibility with the higher operating stresses due to the high-lift cams and the rocker shaft wall is thicker for greater rigidity." (from 1954 TRUCK ENGINEERING FEATURES - Chevrolet/GM) That same manual seems to indicate that the 261 mechanical valve tappets (lifters) were also made of a different alloy iron, compared to the 235.
The information above was for 1954, perhaps in later years, the 261 and 235 truck engines used the same valve train parts? The Master Parts Manual seems to indicate that 235 and 261 valve train parts were the same from 1956 onwards.
Tim
