| | | Forums66 Topics128,206 Posts1,057,438 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35827 11/30/2001 4:21 PM | Joined: Jul 2001 Posts: 5 Member | | Member Joined: Jul 2001 Posts: 5 | I have an original 4.57 gears rear end on my 53 3/4ton truck. I am looking to swap pumpkins to get 4.10 gears. Owner of a 65 GMC 3/4 says he has 4.10 gears on a Dana rear that he thinks is original.
I don't think original rear on my truck was supposed to be Dana. Am I wrong, is he wrong? According to Jim Carters I can swap my pumpkin from a 67-72 C20 but they are not as clear about the 65 as the thought was this years might not have 4.1 gears.
I can get this 65 pumpkin for $50.00 but shipping will cost plenty so I am hopeful some of you guys can help.
thanks
Dennis 1953 Chevy 3/4 ton[LIST] | | |
#35828 11/30/2001 5:24 PM | | Anonymous Unregistered | | Anonymous Unregistered | Oland, the dana gear carrier will not work for you. The dana rear end is a different animal then your stock GM axle. The stock cover is round, perfectly circular. The dana covers are not round, more squarish, or diamond shaped. | | |
#35829 12/01/2001 12:03 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If the COMPLETE third member can be removed, it is an EATON rear end and was used from the mid1940`s to 1972 in 3/4 ton and 1-ton trucks. (kind of like a frod9-inch thirdmember)
