| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 3 Junior Member | | Junior Member Joined: Mar 2004 Posts: 3 | I have an 88 Gmc and i recently changed motors in it (350 to 305). The oil pressure sensor on the old motor was on the top of the engine in the rear close to the distributor. My new motor (305) the oil pressure sensor is down by the oil filter. Should i move it back up top or will it be fine where it is at? Thank you for your help on my last post too.
sam | | | | | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | If you put it up top you won't have to modify your wiring.
Rust is my favorite color
| | | | | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | the pressure is the same on top or bottom so its a matter of what is easy for you | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Sam58: You will be alright either place as long as the wire reaches put it in the easiest place yes they do wear out. popcorn The truth is Out there (go for it) | | |
