1 members (2-Ton), 167 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#3580 03/19/2004 3:07 AM
Junior Member
Junior Member
I have an 88 Gmc and i recently changed motors in it (350 to 305). The oil pressure sensor on the old motor was on the top of the engine in the rear close to the distributor. My new motor (305) the oil pressure sensor is down by the oil filter. Should i move it back up top or will it be fine where it is at? Thank you for your help on my last post too.
sam
#3581 03/19/2004 4:48 AM
Junior Member
Junior Member
If you put it up top you won't have to modify your wiring.
Rust is my favorite color
#3582 03/22/2004 8:06 AM
Junior Member
Junior Member
the pressure is the same on top or bottom so its a matter of what is easy for you
#3583 03/22/2004 1:18 PM
Sam58: You will be alright either place as long as the wire reaches put it in the easiest place yes they do wear out. popcorn The truth is Out there (go for it)
