| | | Forums66 Topics128,109 Posts1,056,240 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35800 07/02/2004 2:14 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Got my new carb yesterday. Went home and installed it. It runs GREAT. Just off idle response is terrific, no more black smoke, certainly better than my bad old B. I am having a problem with the choke. The YF did not come with any bracket for the choke/throttle cables. I pulled the bracket off the B and with a little grinding it fit on the carb. I cannot get the choke to fully close(Open?). The choke plate will not rotate more than about 20 degrees. It looks like there is a rod that goes from the throttle linkage to the choke linkage and this is keeping it from working properly. I won't be able to look at it again until tonight, but I'm searching for any ideas or experiences. Dave somewhat happy in KC | | |
#35801 07/02/2004 3:05 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The manual choke YF carbs do come with a choke bracket. Often the choke bracket is left on the vehicle, as it is easier to undo the one screw holding the bracket to the carb than to undo the choke linkage. About half of the carbs we receive are missing the bracket.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#35802 07/02/2004 3:12 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The rod from the choke to the throttle is part of the fast idle system. When the choke butterfly is closed, the rod operates a bracket surrounding the throttle shaft, which rotates against the throttle positioner screw, opening the throttle and thus providing for a faster idle while the the choke plate is closed. Assuming you have a complete everything correct carb, this rod will not interfer with the choke closing.
