3 members (RoadsScholar, Gdads51, Gray_Ghost), 120 guests, and 4 robots.
Topics128,078
Posts1,056,021
Members48,433
#35800 07/02/2004 2:14 PM
Got my new carb yesterday. Went home and installed it. It runs GREAT. Just off idle response is terrific, no more black smoke, certainly better than my bad old B. I am having a problem with the choke. The YF did not come with any bracket for the choke/throttle cables. I pulled the bracket off the B and with a little grinding it fit on the carb. I cannot get the choke to fully close(Open?). The choke plate will not rotate more than about 20 degrees. It looks like there is a rod that goes from the throttle linkage to the choke linkage and this is keeping it from working properly. I won't be able to look at it again until tonight, but I'm searching for any ideas or experiences.
Dave
somewhat happy in KC
#35801 07/02/2004 3:05 PM
Carburetion specialist
The manual choke YF carbs do come with a choke bracket. Often the choke bracket is left on the vehicle, as it is easier to undo the one screw holding the bracket to the carb than to undo the choke linkage. About half of the carbs we receive are missing the bracket.
Jon.
The Carburetor Shop
#35802 07/02/2004 3:12 PM
The rod from the choke to the throttle is part of the fast idle system. When the choke butterfly is closed, the rod operates a bracket surrounding the throttle shaft, which rotates against the throttle positioner screw, opening the throttle and thus providing for a faster idle while the the choke plate is closed. Assuming you have a complete everything correct carb, this rod will not interfer with the choke closing.
Jon.
The Carburetor Shop
