0 members (), 91 guests, and 3 robots.
Topics128,095
Posts1,056,067
Members48,433
#35790 02/17/2002 2:12 AM
I just got four brand-new Toyo tires from my uncle for free. I thought I could put them on my truck, but i'm not sure. My rims are 15 inch appliance rims. The tires I am running on them now are 235/75/R15's. The tires I just got are 205/65/R15's. Will these fit? I dont know if they are wide enough to seal to the rims. Any help would be appreaciated. frown frown frown
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
I would take my truck and the tires to a reputable, local tire shop and have them tell me. Those new tires would be a little narrower and a little shorter. They will probably work just fine and give you easier steering too.
But, rimsizes have their limits and I would check with the professional tire jockey.
54 3100 with 235
62 flatbed dump C60 with 261
according to the Toyo website click here your tires are good for a rim width of 5.5 to 7.5 inches.
Fred
52 3600
69 C-10
#35793 02/21/2002 11:13 AM
how much would this change my highway speed/RPM's?
Jonathan S. Keffer
#35794 02/21/2002 12:41 PM
gmcfan, i'm going through the same thing right now with my truck. The best advice i've seen was the gentleman telling you to take it to a tire shop. Currently running a 225-70r 14 front on a fenton rim and a 245-60r 15 on rear. the rims are 15 x 6. Its the street rod look and a look I want to get away from for economic purposes. The tire man suggested that I keep the look and recomended this. 15 x 6 3 5/8" back space rim on front w/ 225 70 15's front, 15x8 4" back space w/ 275-60 r 15's rear. I would like to go with the same all the way to be able to rotate. He said 255 70 15's. But he said it would change the look of the truck drastcily. As far as rpm i'm sure you already know the taller the less I believe. Hope this helps.
#35795 02/23/2002 11:35 AM
GMCFAN,
AS OTHERS ABOVE, BRING THE TIRE/WHEEL ASSEMBLIES TO A TIRE SHOP. THERE THEY WILL BE ABLE TO CHECK THE FIT OF YOUR NEWLY DONATED ITEMS.
THINGS THAT WILL CREATE PROBLEMS ARE: OFFSET OF WHEEL/TIRE COMBO CAUSING THE TIRES TO RUB ON FRAME OR FENDER, RPMS TOO HIGH(OR LOW) FOR THE ENGINE TO REV CORRECTLY, CLEARANCE IN BACK IF THE BED IS LOADED HEAVY.
REMEMBER, IF THE RIMS ARE TOO NARROW FOR THE TIRES, ALL THE TIRES WILL DO IS WEAR FAST IN THE CENTER. GOOD LUCK
