11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible),
109
Mod | | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 5 New Guy | | New Guy Joined: Jul 2007 Posts: 5 | Hello bolter`s,
Bought a new bed with no hole`s drilled in bedsides,front panel and rear cross sill.Can anybody help with location,dimension of hole`s and bolt size? Any help will be appreciated.Thank`s
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Are you still using original cross sills under the bed ? If so, holes in rear cross sill will need to line up with existing. If not, becomes a function of how many planks you plan on using across the bed. Bed strips bolt down thru the gap between the planks, and into the cross sills. Holes in front panel flange are centered on the planks. Holes on bed side flanges need to bolt thru ends of cross sills for support. I can send you pics of my '40, but it isn't entirely stock. | | | | | Joined: Jul 2007 Posts: 5 New Guy | | New Guy Joined: Jul 2007 Posts: 5 | I`m going to be using original cross sill if possible.The bed wood is not the problem.I`m talking were front panel bolts to bedsides and rear cross sill bolts to bedsides.The truck will have a 396 /400 and 12 bolt rearend,22 wide rear tires.I`m going to need all the help i can get.You can send pics. Thanks | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Send me your email.I will snap some pics of my bed - see if it might help. | | | | | Joined: Jul 2007 Posts: 5 New Guy | | New Guy Joined: Jul 2007 Posts: 5 | My e-mail is [email protected] Thank`s for helping. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If you haven't already done so, have a look at Mar-K website. They have a lot of good info there as well. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | Thanks for the plug britcon, but there may not be much on the site that can help him with this one. The front bed panel is the same from 40-45 so if you know someone with one you can get a pattern from them. There are 4 bolts on each side of the front bed panel. All 1/4"-20 X 5/8" hex head bolts. The front bed panel also uses a long threaded rod that attaches through the top curl to each bed side. We sell a threaded rod and hardware kit for this. The rear cross sill is also the same from 40-45. You will use 4 bolts on each side of the rear cross sill that are 5/16"-18 X 3/4" at the bottom of the rear cross sill and bed sides. Then you will need 2 more on each side to hold on the hinges. We sell a hardware kit for this as well. It will be difficult for you if those bed sides are not prepunched, as at least one of these holes is nearly impossible to reach to put a nut on. When we make these parts, all the holes are punched in the correct locations and there are welded nuts in the areas that are impossible to reach.
