7 members (TUTS 59, Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, 1 invisible),
129
Mod | | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 31 Apprentice | | Apprentice Joined: Nov 2007 Posts: 31 | does anyone know what posi unit i can use in the rear end houseing? or has anyone ever welded the gears to make it posi.. and if you did how did it work???it's a 1958 chevy apache with a 390 limited rear end
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What year truck and/or what rear does it have? Welding the spiders can be done, but I would not reccomend it. First off, it'll make the rear act as if it had a spool in it, very bad for street driving as it will not allow for any differential action. There's also the chance of failure of the welds if not done properly, which will lead to differential failure. Leave the welded spisers to the budget off roaders/truck pullers.
Bill Burmeister | | |
