6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#357632 01/07/2008 4:45 PM
Hi guys, I could use a little advice. The floor in my 37 cab is cracked out around the rear mounting holes,(chunks out about the size of my fist). I'm going to have to cut out the rear of the seat pedistal to get at the damage, and weld in a piece the width of the cab, probably doubling up the metal (16 ga.) around the bolt holes. This patch will extend a few inches into the recess where the gas tank sat. Tha cab is on a dolly now,no doors. I left the dash in for support, and welded a piece of angle across the bottom of the front cab mounts on the firewall side. Do I somehow need to support the rear of the cab before I cut this floor panel out?? Thanks for any help! Jeff
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
wahoo40 #357773 01/08/2008 12:37 AM
I'm not familiar with a 37 cab but generally speaking you are advise to take all precautions to avoid distorting your cab when you replace sheetmetal. Some is more critical than others structurally, but all play some role.
Be sure the cab is on a flat surface and reasonably braced. After you cut the damage and tack the replacement in place, hang the doors to see if there is any problems with them. If not, finish welding by skipping around your patch. Do not try to run one continuous bead.
Be very careful, go slow and you should be fine.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman, thanks for the shot of confidence!
