0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | I don't remember the first year in which new vehicals required unleaded gasoline, but that year and thereafter the engines necessarily required hardened valves and valve seats. Now, when engines manufactured prior to that time are rebuilt, I assume it is common practice to install hardened valves and valve seats to prevent burning. Valve clearance specifications for those older engines allowed sufficient clearance to prevent burning even with leaded gasoline. The specs for my 1960 235ci calls for .006in for intake, and .018in for exhaust. Even with rebuilt rockers, the exhaust valves are somewhat noisey with the .018 setting. My question is this: has anybody researched/experimented with less clearance for the exhaust? It would seem that somewhat less clearance could be tolerated now that we have hardened valves and valve seats. meansam | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no "necessarily" about it Sam, our old low compression 235's do fine without hardened seats, tho most [not all] will go that route if the engine is being rebuilt .... valve seat recession has to do with adjusting the valves too tight, way more than the type of gas, and if the 235 valve train doesn't have a nice 'sewing machine sound' they're too tight and you'll have problems regardless of what seats are in it ... go with the designers specs  Bill | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | meansam, Give em clerance and let em click unless you enjoy doing valve jobs. Cleon | | | | | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | I'd much rather hear 'em than fix 'em.
Thruwurkin
Half Ton Will Travel God bless America...One nation under God
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Remember, Chevrolet stands for; Can Hear Every Valve Rattle On Lifter Every Time
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | Remember, Chevrolet stands for; Can Hear Every Valve Rattle On Lifter Every Time  This is most appreciated by those of us who have run a 30-30 Duntov cam Ha Ha Doug | | |
