1 members (Truckrolet),
154
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 74 | I'm considering purchasing a VintageAir Sure Fit A/C unit for my 56. Does anyone have any experience installing such a unit? Is it pretty elementary? What are the gotchas / things to consider?
Thanks in advance for your input!! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I wish I could help you. I wanted a Vintage air unit for my '56 last July but no one could deliver for 6-8 weeks. So I went with Hot Rod Air. Big mistake. It still isn't working right. Their techs have no idea what's wrong. They've had me change the dryer 5 times, the expansion valve 3 times. I sent the evaporator back for them to check out, now the system won't hold a vaccuum. I've lost track of how many cans of r-134 I've put in it then released into the atmosphere.
If I had it to do over again I'd wait 10 weeks for Vintage Air. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put the Vintage air combination system in my 70. It works good but I have some moisture issues. I wish I had used the Shure fit. I used the factory compressor & a savage yard condenser. Makeing up the hoses was a hassle. One of the control switches is kind of dainty & broke while I was installing it. They sent me a new one. All in all i,m well pleased with it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I have been looking at Old Air Products because thier controls match the Taskforce deluxe panel has anyone had any experience with the Old Air system for the Taskforce trucks?
| | | | | Joined: Mar 2007 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 69 | Never a 56 but I have put 5 in 47-53 2 were complete and the other 3 were in a total rebuild stage. All very easy and had them done in 1 day. If you can read a schamtic and have a place that can crimp 4 hoses you will be fine | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | HH, I've used the Old Air hurricane kit in my 54 truck. Installation was straightforward and performance has been outstanding. There product and finish is of good quality. I went with Old Aire instead of the Vintage unit because of the ease of getting at the main hose connections which are on the engine side of the firewall. The advantage of this is that you don't have to wedge yourself up under the dash to make the final connections. The disadvantage is that the connections are very visible on the firewall.
They provided all the necessary mount brackets for the compressor to engine as well as the bracket to mount the alternator or PS pump above the compressor. Their hurricane system has a 3 speed motor which gives you a "Hurricane" volume of air to do the initial cab cooling and a low speed which allows you to smooth your hair down and carry on a normal conversation. They provided perfectly formed hard lines from the condensor through the core support that required no core support alterations. The underdash evaporator used 2 existing holes, from the stock heater that is removed (I got their kit with the included heat), to properly position the unit and required only 2 additional 1/4" holes in the firewall. They even included the insert needed when you shorten the stock glovebox and the cable controlled shutoff valves for the heater. All hardware was included and the drive belt was the only item not included in the kit.
I would buy the kit again if I wanted to air condition another project truck. There are some pics of the install in my webshots album.
Dave | | |
