| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | I am having a 235 built. It has a casting date K216 which I translate to November 21, 1956. The stamping on the serial number pad is F1127A. I translate this to be Flint, November 27, and the A means standard 235, model 15-21-2400. See this link 1957 235 identification It had solid lifters. Is this a truck motor or a base model stick shift car motor?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's a stick shift passenger car angine. 1500, 2100, and 2400 are the passenger car line, 150, 210, and Bel Air, respectively.
Bill Burmeister | | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | That is what I thought it might be. I thought that by 1957 the passenger car engines had all gone to hydraulic lifters. I guess not. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I was told (always dangerous) that all 1956-1962 passenger car 235s had hydraulic lifters. This Master Parts Catalog does not show mechanical tappets (lifters) on a 6-cylinder passenger car engine in 56-57. | | |
