1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#348731 12/14/2007 6:29 PM
On an AD burb how can I get power to the tail light on the left rear barn door without using the stock spring loaded door jamb switch? Mine is toast. Is there a loom type thing that can be run through the door jambs that the wires could be contained in. The barn doors can open 180 degrees. Need to find something that can handle the 180 degree swing. What have some of you other burb owners done? Weeds
Weeds #348818 12/14/2007 10:15 PM
In the hot rod world, they sell a conduit that looks like a spring and goes from jamb to door. Looking at my RB's Obsolete 2005 Issue #32 catalog, they can be found on page 205. Also as part of their power window kit. http://www.rbsauto.com/product.asp?Product_id=222685
More description at the Specialty Power Windows web site, the manufacturer of the product. http://www.specialtypowerwindows.com/powerwindow-wiperaccessories.htm
No personal experience with this product although I've seen them in use and the product has been on the market for ten or more years.
MNSmith #353474 12/28/2007 6:19 AM
Sir Searchalot
Sir Searchalot
One of those old fashioned tubing benders works. The kind that looks like a tightly wound spring, Keeps the tube from kinking. Works to keep the wire from "kinking" also. Cheap too! Bartamos.
bartamos #353488 12/28/2007 7:18 AM
cheapest, and quite sufficient > screen door spring, worked fine on my ol panel for years grin
it's close to what is used on the 55-59 barn doors, loosely held at the jamb end, slips free in a slightly oversized hole in the door edge
Flxible #357242 01/06/2008 4:58 PM
Apprentice
Apprentice
The EASIEST way is to use the spring loaded electrical gizzie.
Go to a competent Chevy/GMC (I stress competent, here!!!) parts person, and have them look up the contact set for a 1993 GMC Safari pass side sliding door contact set. There are two parts, with two separate part numbers required, to do this. I saved the boxes for mine, and will try to dig them out later to post the part numbers.
Anyway, these have two contacts on them...and with NO metal trimming, will fit into the spaces available most satisfactorily.
You can also use this contact set to support two circuits...just get a thin braided flexible ground strap and screw mount into the body jamb and left rear cargo door jamb to provide a proper ground to the door shell. It folds into the door jamb when the door is closed. Of course, the light won't function when the door is open, which is of no consequence.
Steve
you can get them at parts america
They are made by painless wiring. You can also get them from Summit, jegs, Speedway, etc.
