| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 37 New Guy | | New Guy Joined: Nov 2006 Posts: 37 | I just got the new side cover installed on the '56 3-speed tranny. I got the shift linkage hooked up, everything adjusted correctly in the neutral position. Then this is where the problem comes in.
The 2nd/3rd shift rod is hitting the clutch fork and will not allow it to shift into gear. The clutch pedal is adjusted correctly for free play and thus there is not enough clearance for the shift rod.
Am I doing something wrong or do I just need to bend the shift rod to give me the clearance that I need?? Wanted to ask for advice/suggestions before I make the problem worse.
Thanks in advance for any help,
Kent S Butler '56 Chevy 3100 Houston, TX
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there are different rods early and late for up or down facing levers, thought I had some pics, but can't find them - yes the bends need to suit
Bill | | |
