| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | Just wondering if anyone has any experience with 8 volt batteries. I have used them in 6 Volt systems on tractors and at one time, had one in a 51 ford The only negetive I can recall is that I would occsionally burn out a bulb. The 6 volt generator wouls charge the 8 volt fine simply by adjusting the voltage regulator. It seems to be a solution to the slow cranking problem. Any comments? | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | If all your cables are the proper size and your grounds are clean,starter and charging system is in good shape,there shouldnt be a slow cranking problem. Lotsa times a cable will get changed with a smaller gauge,,then the problems start. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Any comments? Marty is correct.
. . . a simple solution to slow cranking problems.
1. 2/00 battery cables - both cables (unless care has been taken, most cables used over the past 40 years are for 12v systems and inadequate for a 6v system). 2. Good, clean connections at all ends of battery cables and at all ends of all ground cables. 3. Rebuild the starter (or get it rebuilt or buy a new starter). and/or 4. Get a good 6v battery (such as an Optima Red Top).
If all the above do not result in adequate cranking, maybe your engine is too tight.
Tim | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | If all your cables are the proper size and your grounds are clean,starter and charging system is in good shape,there shouldnt be a slow cranking problem. Lotsa times a cable will get changed with a smaller gauge,,then the problems start. What Marty said....Joe | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ditto the above. An 8v battery is a bandaid for a different problem.
| | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Here is a word from someone who is using an 8-volt battery. I bought it before I started reading the posts from the wiser guys on the Stovebolt page. On the one hand, after having followed these kinds of posts for a coupla years, I will go back to a 6-volt battery when my current one dies. The last few posts and many others like them make a lot of sense to me. On the other hand, I have had none of the problems (yet) that the wise guys have predicted. Contrary to the advice of the Parts Store, I had to adjust the voltage regulator (of course), but since then I have had no problems. It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Still using a 8v in the 49 just because that is what i had at the time. this sping will put the 6v back into it, had to small of a cable on the pos. side, should be fine now | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | Thanks guys for the replies. I realize that an 8 volt would only be a temporary solution to the problem of slow cranking,the starter likely needs a rebuild. 56 years isn't bad for starter life!! All the cables are new,(and correct) so I guess we'll go with a rebuild kit. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | One additional thing I did that helped mine a lot is connecting the ground cable directly to the starter. That makes the current path direct instead of traveling through a bunch of rusty bolt connections.
