7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny), 102 guests, and 3 robots.
Topics128,071
Posts1,055,901
Members48,429
#35623 11/15/2001 2:57 AM
Well, the 261 I thought i bought turned out to be a 235, or so i think. The block number is 3769716, which indicates a 58-62 235, yet on the pad where the captains bars would be for a 261, it has D261 cast into the block. I figured that meant it was a 261. Plus, i compared the rods to a picture i have and they appear to be 261. Is it a 235? Oh, It also has an "848" head that came with it, indicating its a 235. Are these "high" compression heads worth anything? THanks a lot.
1955 Chevrolet 210 2 door Sedan
a 30,000 mile UNMOLESTED original, now my daily driver! Original 6 cylinder with a rebuilt '66-'69 Saginaw 3-speed Overdrive. Synchro low! Otherwise, everything original down to the spare tire. Interior is like new. Needs paint, but absolutely zero rust.
#35624 11/15/2001 10:51 PM
That D261 is the date that the block was cast. It reads as:
D= April
26= 26th of month (April in this case)
1= year '61
It's a coincidence that it happens to read "261," and a confusing one!
As far as I know, the rods would look the same, but I'm not sure if they would be longer from 235-261. Hope this helps.
6 > 8
-Keepin' Things Inline-
#35625 11/16/2001 2:14 AM
Check out : http://www.inliners.org/becks/BCN2.html
1960 Chev Trk Engine block F0361A block casting number 3769716
1961 Chev Trk Engine block F1204J block casting number 3769716
So, it looks like the block is a 1960 or 1961. With B.J.'s information, this seems to confirm a 1961 block.
Tim
