4 members (burgundybolt, Hotrod Lincoln, wilbur53, 1 invisible), 90 guests, and 3 robots.
Topics128,086
Posts1,056,333
Members48,442
I know there is a 2 speed for the Chevy 3/4 ton. Any one know where I might find one or any way of adapting a newer one to an old truck. Have the 216 with a 4 speed. Not sure what make the 4 speed is. The truck still uses a 6 volt system.
Keith and Kim
1942 Chev 3/4-Ton Flatdeck in the Gallery
Victoria, BC, Canada
Keith I'm not aware of a 2 speed for a 3/4-ton. Are you sure you're not thinking of the 2-speed rear axle using in 1-1/2 ton and 2-ton trucks?
I saw one on a farm truck in the mid west, a 3/4 ton with a deck on it. Do you think I can find it again. They showed it mounted behind the tranny with a short driveshaft between them. It actualy was hanging from the xmember. If I recall it used a planetary gear type setup to change the ratio. Wish I had saved a picture of it.
Keith and Kim
The Gearvendors Overdrive would look like that and could be a good choice, but it is spendy.
I believe it is called a brownie, and as I understand there were a variety of them, 2 and 3 speeds. The big truck guys probably know more about them. Probably not too many of them around.
Fred
Does the 42 3/4 ton have a full length torque tube, or does it have an open rear diff? My 1940 3/4 ton has the torque tube so it would be difficult to modify it in such a way... unless the overdrive mounted in between the 8 inch extension and the transmission. Period correct overdrives are out there, but it is very difficult to find all the pieces to make em work.
Mine is an open shaft. The photo I saw had a short shaft between the tranny and overdrive. I'll do some more searching and check out Gearvendors. I'd rather do this than put a different set of gears in the dif
Keith and Kim
The overdrive I'm looking for is a Truckstell overdrive. Anyone know where I might find one
Keith and Kim
I would like to find a Truckstell "Tip-Toe-Matic" overdrive myself. This has been discussed on this site before. Do a search for truckstell. Somebody posted pictures of the one they had. I look on eBay at least weekly for one but have not seen one yet. I did buy a copied assembly manual though. Good luck.
Professional Novice
I had a Columbia two speed rear end for my old F*^$ when in HS and it had a torque tube rear. It seems like someone would still offer such a device especially with gasoline becoming a hose-armed bandit.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Since a 42 3/4 ton has basicly the same rear end as a 1/2 ton I would think it would be easier to change the gears,find a center section from a mid 60s 1/2 ton with a better gear and with a couple gaskets and some gear lube you would be done in a couple hours at the most. Jeff
k10 Offline
I have a Truckstell installed in my 1945 GMC. It combines with the 3.55 Ring and pinion for quite a nice highway ride. I can pass most anything-including gas stations!
As far as I know, all Truckstells are designed for use with column shifted vehicles. Mine is a floor shift and does not use the extraneous controls shown in the Truckstell manuals.
I also happen to have a spare one. In case anyone was thinking of PM-ing me--I paid dearly for it.
I know a guy in Washington that has one, and I also got the book about the Truckstell. Did get an email about one and hope to hear from the gentleman again. Yeh, just put $80 bucks in the tank and didn't even fill it.
Keith and Kim
