| | | Forums66 Topics128,282 Posts1,058,494 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35605 10/29/2002 5:17 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 | I just purchased a set of full length headers for my 215 pontiac six with a single barrel carb. with no real mods to it other than a pertronix ignition. My question is one of my friends told me that with the headers installed, my single barrel carb. won't be up for giving me reliable service. Since it's my daily driver (63 chevy pickup 1/2 ton) I was wondering before I install the headers if I am going to hurt anything, driveability-wise.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!) 1950 Ford 2 door sedan-project
#35606 10/29/2002 7:30 PM | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | I think he was referring to the heat riser that normally comes from the exhaust manifold, designed to help with those cold starts. The exhaust warms up the carb, and as soon as its hot the spring loaded dingus closes off the flow of heat.
When using headers, you have the option of hooking up a water heated plate under the carb, or ditching the system entirely. Search the archives here, I'm sure you'll find gobs of info - though not on that Pontiac engine.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#35607 10/29/2002 8:36 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 | What I think my friend was referring to was the scavenging effect the headers will have. He says the headers will scavenge the exhaust a lot better (duh!) which in turn will make the single barrel carb. virtually useless. I just want to know if I need to step up to a 4barrel carb to compensate.
P.S.--the pontiac 215 is the same engine as the chevy 230- it just has a smaller bore.
#35608 10/29/2002 10:42 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Headers won't make the carb useless, you will just need to re-jet it because the mixture will now be too lean- the air in the cylinders will be cleaner so you will need more fuel to make the mixture right. The 1 bbl carb will be a bit restrictive but it will work just fine if you set it up right. You have a rare engine there and I applaud you for not getting rid of it.
#35609 10/30/2002 9:13 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 | Thanks for the info. I'm probably going to roadtest it without modifying the carb for a little to see how it goes. I'll probably end up re-jetting it anyway. I'll keep you up to date on how it's coming along.
