8 members (Gdads51, LAROKE, Phak1, JW51, Nick in Manitou, FAST55, Bill Hanlon, dt235sd),
86
Mod | | | Forums66 Topics128,138 Posts1,056,751 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 17 Apprentice | | Apprentice Joined: Aug 2006 Posts: 17 | Been reading in the forums about the different style hinge pin kits to "fix" the hinges on our '54.
Who makes the best kits for repairing our hinge pins? Should I look for the brass bushing style or the stand-alone enlarged pins?
Has anyone ever used the hinge pin kits from LMC truck?
Thanks, Thomas
| | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | My personal experience with the brass bushing slightly enlarged pins has been excellent. I got some help & guidance from fellow bolters and it all went well. The kit I had came with the truck so I am not sure who makes the best kits. I do know that Classic Parts sells them at a very good price. Their stuff so far has been great. Check out Photbucket pics. on this subject. Hope this will help. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I just did both of my doors and used the Classic Parts they fit perfectly. This is a great link on how to do it. https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/328064#Post328064I will tell you that having redone my hinges and removing my doors a couple times that a simple trick to reassembly is to rotary file the door where the hinge slips into it. I then use a dab of grease on the hinge itself and they slide right on. I can now remove and install the doors myself in just a couple of minutes.
| | | | | Joined: Aug 2006 Posts: 17 Apprentice | | Apprentice Joined: Aug 2006 Posts: 17 | Great, thanks for the good info. Looks like I'll order the pins from Classic Parts.
Much appreciated, Thomas | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | I am assuming the process is basically the same for the TF hinges? Thanks. | | |
