4 members (78buckshot, klhansen, 2 invisible),
147
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35585 07/10/2003 12:21 AM | Joined: Jul 2003 Posts: 10 New Guy | | New Guy Joined: Jul 2003 Posts: 10 | WHAT TYPE OF FITTING IS USED FROM THE 1/8 PIPE TAP AT THE BOTTOM OF THE TANK? I'VE REPLACED THE TANK AND I CAN'T STOP THE LEAK. WHEN I BOUGHT THE TRUCK IT USED A STRAIGHT 1/8 X 3 PIPE NIPPLE. | | |
#35586 07/10/2003 4:12 AM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | I just came in from working on mine. It is the original tank and it has an 1/8" pipe nipple coming straight out the bottom of the tank. Then the shut off valve, this is where the flexible fuel line connects. In the bottom of this brass fitting is a plug which can be used to drain the tank. I didn't have a problem with the nipple leaking but the shut off valve was dripping. I finally got the packing nut tight enough to stop the leak.
I would use Teflon tape on the threads of the nipple before I screwed it into the tank and on the other end of the neipple before I screwed anything on to it. | | |
#35587 07/10/2003 7:30 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also seal it with Permatex Hylomar instead of the teflon tape. Either one should work.
Fred 52 3600 69 C-10
