I think I had mentioned here a while back that my 96 s-10 transmission was slipping real bad, and that I had changed the filter a fluid and it mad a improvement. This thing is a 4 banger with the 4L60 automatic in it. Well its been slipping again when you accelerate even when your in reverse.
Sat. I went and made a offer on a 99 toyota tacoma 4x4.
So Sunday I was clean-up the s-10 make it look good for trade in and hope they wouldnt test drive it very far. Any way I noticed the tires were a little low. All were about 10 psi low so I aired them up. That made a big inprovement in the slipping problem!
What would cause that? Is it the tourque converter like the dealership thinks? Thanks again!
