3 members (Hush, Peggy M, 1 invisible), 116 guests, and 2 robots.
Topics128,196
Posts1,057,395
Members48,471
I have a 56' 1/2 ton rearend that I am considering putting in to one of my other trucks and change the gearing in it.
I am interested in changing it into either my 51' chevy 3/4 ton which has a 4.90 gearing or my 49' 1 ton with 5.14 in it.
I also want to change the front to a six bolt and need to know if there is anything I can put right on the axle.
If I can change the rearend I hope to put a T-5 tranny in with it.
I think this would make it easier on the engine if I can do all this.
Collecting is fun, as long as momma enjoys riding in them.
You can get a '68-'72 center section that will fit the 3/4 and 1-ton axles (provided that they are not torque-tube axles). These had an optional 4.11 gear ratio. They were often found in trucks with automatic transmissions, but mine came from a 4-speed truck. It might be another option to consider. If interested, search the archives as this swap has been discussed several times.
1954 GMC De Luxe COE
The standard ratio for 55-62 1/2 ton is 3.9. There were 4.11,3.7,3.38 optional ratios also.
My Blog
How should you be able to tell which it is?
Divide the number of teeth on the ring gear by the number of teeth on the pinion. A 3.9 will have 39 on the ring and 10 on the pinion.
My Blog
Y
Y Offline
The pinion gear will also have a date code, and the number of teeth stamped right into the top of it. The pinion in my 61 Apache has GM 11-60 39-10 and a part number stamped in it. The 39-10 being the tooth count for the gear set.
Hey, would anyone know the standard gear ratio on a 55 first series? I have a 68 camaro 283 small block with a 4 speed borg warner transmission. I am assuming that I have the original truck rear end. I would like to go to a lower gear but am not sure what gear ratio I have. Truck is in storage right now and I won't be able to get at it till this spring.
thanks,
Chris
Chris 1955FirstSeries
