| | | Forums66 Topics128,162 Posts1,057,057 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Does someone know the max pressure in the braking system? I'm working on some custom parts and need the value for the design.
if it dosen't need fixed, break it
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If it helps, the McMaster Carr catalog gives the max pressures for regular steel brake line as 6,000 psi for 3/16" and 4,500 psi for 1/4". I don't know if this is max working pressure with what factor of safety, or burst pressure, but it may get you in the ball park so to speak.
What are you planning to do?
Grigg | | | | | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | | | |
