| | | Forums66 Topics128,149 Posts1,056,814 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 45 | Does anyone know of a relatively simple set-up for new (modern) brakes on a 1949 Chevy 6400 Truck? I'd like to do disks, if they are out there.
Thanks.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Nothing simple...
I have installed Disc brakes on my 6400, but they came with newer axles, the rear is simple, the front takes some work. It is not recommended to have disc on the rear without the front frist.
My method allows you to keep the original bolt pattern front and rear (5 and 10 on 7.25" circle), the center hole is larger, but new wheels are available, or you can have your old 20" ones bored out to fit.
Check out my pictures on the link below.
Grigg | | |
