2 members (2-Ton, 1 invisible), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#354625 12/31/2007 3:58 PM
Anyone one know where to find a replacement fan for a 54 235? I tried the flex blades but the water pump holes are to small.
ryanb790 #354627 12/31/2007 4:05 PM
That's an easy one. I see them on ebay all the time or maybe you could post in the parts wanted section of this site. It shouldn't take long to find one.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Old Gold #354694 12/31/2007 7:28 PM
I'm running a slightly modified 6 blade Flex-a-light fan on my 54 truck with the 1" waterpump snout. Summit Automotive has an inexpensive FLX-1615P center-mount-blade fan that works great. To open up the snout hole, use a 1" plastic circle template, scribe a sharp line for the hole and do some hand rat-tail filing. I've experienced NO vibration problems from this modification and my engine runs at thermostat temperature.
The center-mounted blades will give you adequate fan/radiator cleararance as well as clearance to your Harmonic balancer and alt/generator. The rear mounted blade flex fans will present clearance issues.
If by chance you are looking to maintain a stock look, you can disregard the above info. However, if you're interested in improving the cooling on your truck you can't beat the 6 blade.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
