1 members (baldeagle),
89
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 59 | Anyone one know where to find a replacement fan for a 54 235? I tried the flex blades but the water pump holes are to small. | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | That's an easy one. I see them on ebay all the time or maybe you could post in the parts wanted section of this site. It shouldn't take long to find one. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I'm running a slightly modified 6 blade Flex-a-light fan on my 54 truck with the 1" waterpump snout. Summit Automotive has an inexpensive FLX-1615P center-mount-blade fan that works great. To open up the snout hole, use a 1" plastic circle template, scribe a sharp line for the hole and do some hand rat-tail filing. I've experienced NO vibration problems from this modification and my engine runs at thermostat temperature.
The center-mounted blades will give you adequate fan/radiator cleararance as well as clearance to your Harmonic balancer and alt/generator. The rear mounted blade flex fans will present clearance issues.
If by chance you are looking to maintain a stock look, you can disregard the above info. However, if you're interested in improving the cooling on your truck you can't beat the 6 blade.
Dave | | |
