1 members (KEVINSKI), 119 guests, and 2 robots.
Topics128,162
Posts1,056,943
Members48,458
Junior Member
Junior Member
went for about a 40 mile ride in the Panel truck yesterday.....water pump started growling, checked the play in shaft on fan....no play,no leaking waterpump.....any additive to quite down the waterpump.....till i replace it??? thanks for all replies......
1950 Chevy Panel 310
I read somewhere that you can buy 'water pump lube' at the auto parts store, add directly the radiator.
According to the article, years ago, antifreese came with the lube already added.
Tried the water pump lube and seal rejuventor. Week later forced to change the pump. It did nothing to help. Bite the bullet and change the pump because some of these "miracle" fixes are just snake oil! Are you certain it is the pump. Try running the motor without the belt and then you can hear if it is the pump or something else.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
