5 members (Bigdogg, Nick in Manitou, TUTS 59, Bill Hanlon, 1 invisible), 55 guests, and 3 robots.
Topics128,176
Posts1,057,122
Members48,463
#354343 12/30/2007 9:55 PM
Apprentice
Apprentice
Yesterday I was putting Lucy away for the winter. After running the engine for 5 minutes I noticed a fine Mist coming from one spot on the rad. Should I try a can of stop leak or should I pull the rad out and have it recored now. I bought the rad used 2 years ago. Lucy is a 52 chev 1/2 ton.
Since it's going to be out of use for a while, just do a good drain job, including the block petcock, and store it away dry. Get the radiator recored or repaired, and treat the old gal to new belt(s) hoses, and a water pump when you do a wake-up in the spring. Stored dry, there's a better-than-even chance the pump seal will leak when it's put back into service.
If she's being put up for the winter, now would be the time to take care od this. I would suggest taking the rad out, and having the local rad shop check it out. They'll be able to test and assess the condition and suggest a course of action. It could just be a minor pinhole, easily fixed. If it's savable, fixing it wold be better than spending the $$ on a whole new core that may not really be needed.
Bill Burmeister
Ex Hall Monitor
Ex Hall Monitor
Ditto the above. Stop leak can sometimes plug a heater core.
Old timers use to swear that potato soup would fix any leak be it in the rad or the engine block. They would drain the block and rad then cook up the soup and fill the rad and block with the soup. Then run the engine till it was hot and drain out the soup while the engine was running and Let it sit and dry out. They said it would work.
~Jim
I've seen more than one oldtimer dump a box of black pepper into a radiator, and watched the leak dry up. Don't know how long it lasted, but it got the guy home, anyway!
jdl Offline
Hotrod Lincoln, I made a pot of beans awhile ago and poured way too much pepper into the pot. As the beans cooked, I found out that the pepper stuck to the sides and turned into a sticky goo. It doesn't surprise me that it works. grin
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Apprentice
Apprentice
Thanks for the advice folks. Looks like I will take the rad to a repair shop. Happy new year
Like Hotrod said, pepper is the answer. When you get your rad to a shop and they find Stop Leak in it, you'll take a good cussin'. The pepper however will stop the leak, and if it needs to be flushed out, comes out easily enough. I always carried a large can of the stuff in my sidebox when I was driving OTR with my Kenworth, and it saved my hide more than once.
Tramp
dj durant
More pix on Flickr
