3 members (Leo, Donf, Youngin' Tut 59), 60 guests, and 6 robots.
Topics128,185
Posts1,057,284
Members48,467
Could you guys help me out here? I'm trying to figure out what goes where.
It appears that this engine was not setup for an oil filter?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I will help with what I know. H, my 54 has a coolant petcock there. Actually, the hydramatic throttle return spring hooks around it. G is oil pressure connection. My engine has a T fitting there for oil to filter and oil pressure guage. F is where the linkage pivot goes for hydramatic linkage instead of the forward position where yours is for manual transmission linkage pivot. E I think may be oil drainback for oil filter. A,B,C,and D, I need help on. I am sure that some of them are for generator mounting bracket but I don't know which ones. Hope this helps a little bit.
I believe that ABC are holes used for side mounts. I know GM shifted to sidemounts during 50's and started casting blocks for sidemount but also had front mount plates for replacement engines on older vehicles. On my truck I have a bracket that runs from A, across B, to D, which holds the generator/alternator.
My 1950 truck had center front mount only
My friends '57 truck, front crossmember, had ability for sidemount or front mount engines. The 235's where casted for side mounts untill front mounts where phased out. This truck had a '62 235 sidemount only replacement engine which I planned to use on my front mount only '50 truck.
I choose to make sidemounts on my frame and instead of milling block and exchanging mounting plate.
Somebody please correct me if Ive drawn some wrong conclusions
Any elaboration on this is greatly appreciated. This engine is going into a '51 half-ton which does not use side mounts.
Woody
Door Art Collection
Hi Woody,
A,B,C,D, Are generator/motor mount holes.
E, Is oil return,if youre running a filter
F, Is another bellcrank throttle mounting point.
G, Is oil pressure,straight off the oil galley.
H, Is block drain.(coolant)
For your truck, youll want to drill the front plate on the motor to accept the front mount.
Thanks to everyone who took the time to answer and especially to the one Super-Bolter who sent photos of the motor mount. You guys are great!
Woody
Door Art Collection
F is the throttle pivot for Passenger car use.
Bill Burmeister
Woody,
This series on a 235 rebuild from the Webrodder site seems right down your alley.
Lots of photos. Minimal advertising. Great info. Photos in Section 1 could have helped answer part of your opening question. My intention of mentioning this is FYI, not trying to advertise for their site or sponsors.
Section 1 Basics and Variations of 235
http://www.webrodder.com/article.php?AID=397&SID=4&CID=15
Section 2 Block Cleanup and Full flow oil filter conversions
http://www.webrodder.com/article.php?AID=398&SID=4&CID=15
Section 3 Crank grinding, bearings on the 235 block
http://www.webrodder.com/article.php?AID=399&SID=4&CID=15
Section 4 Offset ground stroker crank for 235
http://www.webrodder.com/article.php?AID=401&SID=4&CID=15
Section 5 Rear Main Seals
http://www.webrodder.com/article.php?AID=406&SID=32&CID=15
Section 6 Second Version of stroker 4.125 Crank
http://www.webrodder.com/article.php?AID=411&SID=4&CID=15
Section 7 Bores and Deck
http://www.webrodder.com/article.php?AID=416&SID=4&CID=15
Section 8 Cleaning and Painting the Block
http://www.webrodder.com/article.php?AID=417&SID=24&CID=15
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
Thanks Randy,
When it gets that hyper-precise it get scary... wish I had access to that kind of expertise, and could afford it. Oh well, just doing the best I can with the resources I have.
Also a shame those articles can't be printed out frown
Woody
Door Art Collection
