| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35428 07/20/2003 2:26 AM | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | Can anyone suggest a supplier for a steering box rebuild kit. I need upper bearing and sector shaft seal for sure maybe other parts too. thanks alot Wayne. PS its for 1956 1/2 ton
1956 GMC TF 1/2 ton 1955 GMC 500 model (Gumby)
#35429 07/20/2003 3:22 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | try Scotts - select "1955-1959 Mechanical Parts" under group Bill | | |
#35430 07/20/2003 4:26 AM | Joined: May 2003 Posts: 53 Member | | Member Joined: May 2003 Posts: 53 | Thanks squeeze see you in Duncan Wayne
