1 members (1 invisible),
108
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 4 New Guy | | New Guy Joined: Jun 2007 Posts: 4 | I am contemplating a TBI 350 from a 1989 Chevy truck with a 700R4 transmission to my 1959. I have a 1957 with a factory V-8 under toe hood. The distributor cap is awfully close to the firewall. The problem is there only about 8 inches between the front of the block and the radiator in the '57. The '89 has about 10 inches from the front of the block to the tip of the fan clutch. My options are to lose the fan completely and move the '89 engine away from the firewall to have more room for the HEI distributor cap. I can lose the fan clutch fan and install the original fan, but the clearance is still very close. Has anyone completed a project like this yet? If I lose the fan, am I sure to overheat even if I buy an aluminum radiator? I want to stay with the serpentine system on the '89 if possible because it is complete, but I dont want to have overheating problems. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm assuming the '57 was originally a V8 truck. You can mount another radiator support in the six cylinder position, which is about 5 inches forward of the V8 location. You'll have to cut the fender mounts off the v8 support and leave them in place.
I did this on my '56 and installed an electric fan. I used a radiator support from a 2-ton by the way. Whooda thought they were the same? | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | Can't you install a thermo fan? people drop the normal fan and install an electric thermo fan on the radiator. Brendon | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | How's about a skinny electric fan setup? Running without fans is asking for an overheat, but a good set of electric fans is not overly expensive nd will fityour needs very well.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 89 comes with the small dist. If you use it you shouldn,t have any clearance problems. On my 58 carbureted I used the old point type dist with a Crane conversion to solid state. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2007 Posts: 4 New Guy | | New Guy Joined: Jun 2007 Posts: 4 | Thanks for your help. I did not realize that the radiator was situated 5 inches farther forward. I makes sense though as the block is longer than the v-8 block. I was taking measurements from my factory v-8 truck and thought that I would not have enough space. Now I have plenty of space. | | |
