4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#35344 02/24/2002 9:15 AM
hi there people can i reuse the head gasket in my 235 its not damaged in any way can i re coat it with copper spray all because the valve spring broke dropped the collit bent the valve and the conrod i also have a vibration in the drive train i have replaced the universal but getting vibration through the clutch she really jumps around also what grade oil do you use i have a 46 p/up with 235 donkey thanks see ya later
p j a
#35345 02/24/2002 10:36 AM
I would advise AGAINST reusing the headgasket!Make sure you check out the crankshaft as well as the engine block itself.
As for the vibration in the drivetrain, check and see if the tranny mounting bolts are tight first.
