| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35344 02/24/2002 9:15 AM | Joined: Feb 2002 Posts: 9 Member | | Member Joined: Feb 2002 Posts: 9 | hi there people can i reuse the head gasket in my 235 its not damaged in any way can i re coat it with copper spray all because the valve spring broke dropped the collit bent the valve and the conrod i also have a vibration in the drive train i have replaced the universal but getting vibration through the clutch she really jumps around also what grade oil do you use i have a 46 p/up with 235 donkey thanks see ya later
p j a
#35345 02/24/2002 10:36 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I would advise AGAINST reusing the headgasket!Make sure you check out the crankshaft as well as the engine block itself. As for the vibration in the drivetrain, check and see if the tranny mounting bolts are tight first.
