| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | I finally scrounged up enough parts to put together a "second" Rochester 1 barrel for my truck with a 216. Used a kit to replace gaskets, ball checks, springs, float valve, and accelerator pump. Installed it to test it out. Idles very smooth and throttles up fine at rest. Drive the truck and it wants to stall out upon braking. I set the RPM at 500 and even went up to 750 RPM at idle, but it still wants to die out when coming to a stop. I disassembled and checked all the settings (float level / drop). Can't seem to find the problem. This carb also runs leaner than the original, but will not "run" satisfactorily on the moving truck. Suggestions? I welcome all input. Thanks, BW | | |
#3533 04/23/2005 10:33 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have worked on many carbs. for 50 years. A long time ago I had a roch. B that did that. I spent hours trying different things & never could fix it. I went to another carb & it worked fine. To this day I can,t figure what was wrong. Sorry I can,t help but if you solve it I would like to know. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Have you checked the fuel pump had this happen before and it was the fuel pump going bad, would not throttle back when you slow down, after replacing fuel pump fixed problem. super250six. | | | | | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | Fuel pump is OK / rather new. Another "Bolter" suggested that the airhorn may be warped and allow gas to dump into the well at stopping / braking. Will check it out on a level surface. BW | | |
