| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35336 10/05/2004 10:29 PM | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | Need to do some work on the clutch but have not pulled it yet. I was under the impression that on my 61 C20 with a 235 engine it is a 10 inch clutch. When I called to order parts the parts guy stated that it is 12 inch. Anybody know for certain? Also, what kind of job am I looking at to replace the throwout bearing, pressure plate and disk? I've never worked on a clutch before. Thanks!
Not quite as lean Not quite as mean, but Still a Marine!
#35337 10/06/2004 1:17 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You almost have to pull it out to be shure. measure the dia. of the disk. Its a really simple one to do if it,s a 3 speed. Alittle harder on a 4 speed. Dont forget the pilot bushing. It will probably need replaceing too.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#35338 10/06/2004 1:33 AM | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | If it is a four speed you will probably need a transmission jack unless you are a lot stronger than I am.Pay attention to how the throw out bearing and the disc are oriented. You can get them in backwards but they wont work that way.
I like old trucks
#35339 10/06/2004 3:16 AM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | I've found the 12" clutches are usually on the heavy-duty rigs, 1 ton and above. There is an 11" option that's available, and also a 10". Your best bet is to take it out and measure before ordering parts. Be sure and remove the flywheel and get it resurfaced, and replace the pilot bushing in the end of the crankshaft. The clutch plate can be installed backwards, and the center hub will drag the flywheel attaching bolts and prevent the disc from releasing fully.
Use an alignment shaft during reassembly to align the clutch and pilot bearing, and it's also effective to use a couple of long, headless bolts screwed into the bellhousing to guide the transmission back into place during reinstallation. Tighten the pressure plate bolts a little at a time to avoid distorting the clutch cover or misaligning the clutch plate on the flywheel. Good luck! Jerry
#35340 10/06/2004 5:54 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | On my '65 w/ SM420 4 spd, it's an 11" clutch. It's not all that difficult. I replaced mine earlier this year and had never done one. Took the whole day but, was up running by evening. You'll definitely want a jack if it's a 4spd. I didn't use a jack but, my buddy we affectionately call Shrek helped me. He's 6' 5" and 290 lbs. The truck was on a lift and even with his strength and size it wasn't easy gettin' that thing outta there. As you're disassembling, try to take mental pictures as your takin' stuff apart. Use a digital camera if you have to. Then reassemble in the same order. One thing we forgot to do was drain out the old oil and that made it a bit heavier (not to mention messier) when removing. When it's back together, don't forget to adjust your pedal. You need to have an inch or so of freeplay. Good luck, David | | |
#35341 10/06/2004 1:31 PM | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | Thanks for all the input.
#35342 10/06/2004 5:44 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The easy way to deal with a SM420 is to use an engine hoist through the passenger door to hold it up from the top.
#35343 10/06/2004 7:42 PM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | Ditto. The extra time required to pull the seat and floor pan is well worth it. These things can be a real pain to line up, esp. with a new pilot bearing, so anything that makes this job easier is worth it in my opinion! | | |
