3 members (Gdads51, J Lucas, Shade Baby), 93 guests, and 1 robot.
Topics128,038
Posts1,055,585
#353190 12/27/2007 5:22 PM
I just got a pair of Carter/Webers for my 235. I've noticed that some of you have installed fuel pressure regulators for these things. Is this a requirement? Then if I install a regulator do I need to install one of those fuel pressure guages too?
Also what is the best way to balance the carbs. I have a cheapie air flow meter that I got from JC whitney to use on my rochesters. Will this work? I know I'll have to adapt it to fit the carter/webers. When adjusting these things, do I adjust the fuel mixture or just adjust the throttle linkage?
Sorry for all the questions but I don't want to mess these things up.
George
Langdon recommends running an inexpensive regulator. I used a Mr. Gasket unit and I put a gauge on it to verify the 3.5 psi. However, I found it is quite accurate so I would say the gauge could be an option. I have a complete set of pics of the setup in my Webshots album.
A word of caution.....when you bolt the adaptors to the base of the carb you will find it is a tight fit. The thick insulator plate/gasket WILL line up if you just take your time and don't try to force the fit. Several folks have had a problem with this. DO NOT TRY TO ENLARGE THE HOLES.
You'll have to do some creative bending to get your linkage from the bellcrank up to the carbs. I would suggest using some heavy copper electrical box grounding wire from Home Depot (18") to use as a pattern. You'll have to mount the exhaust and intake (without gaskets or alignment rings) with a couple of the manifold bolts to get your linkage bends correct. If you're running Langdons aluminum heat plate the rear inboard corner will need to be trimmed to clear your linkage.
Your final installation will be easiest as follows: install the manifold bolts and plates (the center 4) loosely, add the gaskets and rings, then the exhaust (if fentons) I put a bolt in the front hole (in place of the stock stud)and a longer stud in the rear to keep the fentons from dropping. The intake goes in WITHOUT the carbs.....this will let you get to the manifold bolts and get them tightened correctly. Add the carbs after. If you try to put the intake in with the carbs and linkage attached you'll have a tough time getting the bolts tightened. You need to add the 2 longer bolts and plates after you get the manifolds seated. Try to get you bolts tight as they WILL loosen up after a couple hundred miles.
I made some (2)little scrap sheet metal "hats" that sit on top of the carbs to make a flat surface for the unisyn to rest on. Also have some dumdum sealer that I use to make sure they are sealed at the base where they meet the carb. I didn't have to mess with the idle mixture screws at all until after I got them synced. The trick is to get the carbs synced using the idle speed screws and then adjusting your linkage so that they both draw equally at idle. Some folks just use a rubber hose and listen to the hiss....being deaf in one ear eliminated that for me. After I got them both synced I used a tach and vacuum gauge to adjust the idle mixture screw. I didn't have to turn them more than a couple degrees to get them the way I wanted.
I used exhaust heat which was the easier of the two options...it works fine and although I'm only getting about 17-18 mpg I feel confident with a bit more tweaking I can break 20-22 mpg. If I were to keep my cruising speed down to 55 mph I know it would be there now. It's just too easy to run at 70 mph and the sound of the secondaries cutting in is addictive!!!!!
The installation is not something you're going to want to do in a hurry. I can imagine I had the intake and exhaust on and off 3 times before the final install. However, it will be well worth the effort the first time you hit the highway!!!!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Thanks Dave. That's what I was looking for. I've been running dual rochesters for a few years now so the linkage won't be a big problem. I will have to bend up some more fuel line and add in the pressure regulator.
The big thing I was worried about was getting them synced. I have had a real problem with the Rochesters. Most likely because they are not a matched set. Hopefully with the carter/webers I won't have that problem.
Now all I have to do is get my radiator back in. (big holein it) and plop those new carbs on and I'll be set.
Thanks again
George
The linkage kit from Langdon is really pretty simple....it's getting the vertical throttle rod to clear the corner of the heat plate, and the manifold bolt head without binding. I used the stock bellcrank with a heim fitting on the bottom end, and it took longer to get it to go from idle to WOT than I figured. Hopefully yours will be easier.
I've got about 3K on this engine and have checked the state of sync a couple times....haven't needed any tweaking. I think that restricting the fuel pressure/volume to the carb at 3.5 psi is a factor in how well the C/W's perform. Let me know how it works out.
Dave
