2 members (farmallb, Bill Hanlon), 133 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
Y
Y Offline
putting cam into 235 block. Pros, cons of either way? Crankshaft gear was not removed. It's a fiber gear. Thanks
Press the gear onto the cam before you install it. There's a danger of doing damage toithe thrust palte, etc., if you try to force it on after the cam is installed. Be sure to put the thrust plate on before installing the gear, though! It's nearly impossible to remove the new gear without damaging it if you forget to put the thrust plate on before installing it!
Y
Y Offline
Trying to get the thrust plate off of the old cam now. Doubt I'll be able to do it without bending it. May have to take trip to the machine shop. Seems theres always something to hold ya up when there's time to get to it.
Does the old cam have a fiber gear? If so, just break the gear off the hub with a hammer, then split the hub with a chisel. The thrust plate will lift right off once you've got the gear off.
Y
Y Offline
Well, sadly it's too late, have to find another thrust plate. Tried the three arm puller, watching carefully not to bend the plate. Imagine my surprise when the Bas#@7% shattered. I wouldnt have imagined that plate was cast. Hopefully someone else will learn from my mistake.
