6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#3528 02/22/2002 6:23 PM
Junior Member
Junior Member
My '54 235 has come back to life after sleeping in a field for 1-year. I have replaced all ignition parts, cleaned the carb. It appears to be the stock 1-bbl Rochester carb. I am having trouble getting the truck to idle. Can anyone tell me:
> How many turns should I run-out the mixture
screw at the base of the carb?
> How do I adjust the idle speed when I have the
mixture correct?
> The truck doesn't seem to want to start without
a shot of starting fluid. What does this mean?
IT'S ALIVE!!
Thanks for your help.
#3529 02/22/2002 7:01 PM
I turned mine out 2 turns as a starting point, idle speed is then adjusted with a screw on the throttle linkage on the drivers side of the carb toward the firewall. I also noticed that the timing made a big difference in the idle speed. there are several threads about carb adjustment here if you use the search function. what part of indiana are you located in, I am in Fishers In.
Rog
#3530 02/22/2002 7:58 PM
How did you adjust your points? It's tough to get them right with a feeler gauge unless you have a lot of practice. If you can locate a dwell meter, you can be far more accurate.
Fred
52 3600
69 C-10
#3531 02/23/2002 4:57 AM
khacker, in regard to the hard start! as I found out thru this forum, be sure to check that the choke is functioning...that was the key to my easy starting. smile
49' Chev, 3808 platform
