5 members (Rusty Heaps, Oswald, joe apple, Gray_Ghost, 1 invisible), 45 guests, and 1 robot.
Topics128,074
Posts1,055,911
Members48,429
#35284 07/17/2004 2:47 PM
I
I Offline
I have a strong gas smell with the garage closed from the 49 3100. Is this just the way it is with these old trucks, ie evapration from the carb or could it be more. The gas tank cap seals fine and there are no leaks that I'm aware of. The wife doesn't appreciate the smell in her car. THX
#35285 07/17/2004 4:18 PM
Big Bolt Shop Curmudgeon
GET THIS TRUCK OUT OF AN ENCLOSED AREA!
The "odor" of gasoline is not good in an enclosed area. Any gasoline vapor present is highly explosive, and in the summer heat, the flashpoint of gasoline is just right for the least spark to rid you of all of the problems you have been experiencing with your truck.
Open the garage up. Open the doors and windows. Don't start anything electrical (including the vehicles in the garage.
Let the garage air out for a bit (30 minutes), then move the truck outside and leave it there until you find the source of the gasoline vapor odor.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
#35286 07/17/2004 5:05 PM
I dunno about yer 49 but on my 64, the interior always smelled like gas. When I pulled the tank out (the behind-the-seat type) I found a coupla things. First, the gasket that fits under the sender ring was cracked in several places...and a coupla the bolts were slightly loose. Second, the gas cap was of the pressurized (non-vented) type.
What I figger was happeining was as the truck sat in the the sun, the gas would heat up and pressure would try to escape thru the vent in the cap. Ooops! No vent. So it'd work its way out thru the cracks and loose bolts in the ring.
What I did was make a new gasket from a sheet of cork and re-fasten the ring. Then I drilled a small hole in the gas cap (an eco-no-no, I spose) to allow for pressure and volume changes.
No gas smells anymore...but I don't park it in the garage...there's a race car in there. smile
I don't think that a car or truck with a vented gas cap should stink up a garage. So I'd venture to guess that there's something leaking in your truck. You might wanna check the gas cap to see if it's the vented type...if it's not, you might be forcing gas out under pressure.
If you want to absolutely, positively eliminate all gasoline odor, you might consider a vent line on the gas tank that goes to a charcoal cannister. It could be a considerable amount of work, but who knows? It might be worth it to keep peace in the family. Btw, activated charcoal for fish tank filters works great as refill media for those cannisters.
#35287 07/18/2004 12:04 AM
I just took my tank out of my 50 and cleaned it and installed a new sending unit. I put a new sending unit gasket on but didn't seal the screws. When I filled up, I had a terrible odor of gas. Turns out that it was leaking past the screws. When I sealed them, it was went away.
#35288 07/18/2004 12:12 AM
If the original fuel hoses have not been replaced, they are also likely suspects. There are three: Fill hose (from tank to the filler neck) vent hose (from tank to filler neck) and the flex hose under the cab which allows for some movement between the cab and frame. I strongly recommend replacing all three with modern alchohol, benzine resistant hose fresh from the shelf. Be sure to get fuel rated hose! wink
#35289 07/18/2004 1:43 AM
Another possibility is a leaky fuel line or carb. I have to agree, park it outside until you get it fixed.
Fred
52 3600
69 C-10
#35290 07/18/2004 4:23 AM
Maybe it was that burrito from the local mexican deli? I can have my '50 parked in the garage for weeks on end and never smell gas though the carb does leak when I drive it. I would listen to everyone's cautionary comments and keep it outside until the smell can be taken care of.
Craig
