8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#35250 01/18/2002 12:17 AM
57 chev 3100. 235, granny tranny 4sp. clutch is slipping. daily driver so I want to get the parts before I do the job but I need to know if I need a 10" or 11" clutch. Can't seem to find the info readily, so thought i'd ask you guys if anyone knew off hand, or could it be either?
cheers,
Ryan
#35251 01/18/2002 12:23 AM
Get both and take back the one you don't need?
Paint & Body Shop moderator
#35252 01/18/2002 1:08 AM
I've got a '54 Bel-Air and its supposed to use the 9.5" clutch. I use the 10" clutch for a '55 truck. As long as the spline count is right, and you have the flywheel resurfaced, you can use the 10". Or the 11" if it'll fit the flywheel. I would say to buy both kits, but each clutch disk/pressure plate/throwout bearing kit is 200 clams from NAPA.
hope this helps
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#35253 01/18/2002 2:28 AM
10" standard, 11" optional. Could have either.
My Blog
#35254 01/18/2002 7:17 PM
Thanks Dave, that's the info I was looking for. Guess I'm buying both. If I have a 10" and want to upgrade to the 11", is it a direct swap or are there extra bits to buy? Splines should be the same I would think, is the flywheel different?
Ryan
#35255 01/19/2002 4:32 AM
Yes the flywheel is drilled differently to accept the larger pressure plate.
My Blog
#35256 01/19/2002 5:06 AM
What is the stamped engine code? Might be able to tell by that, THD or FLG had heavy duty tranny, probably heavy duty clutch.
#35257 01/19/2002 5:58 AM
As far as stamping goes, I think I'm out of luck. My truck is Canadian built (model 1300 instead of 3100) so may not be valid. Not nearly as much info as to numbers as the U.S. trucks. Good suggestion though. I'll have a look tonight.
cheers,
Ryan
