0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#35248 05/13/2003 1:34 AM
Ok how do you get the spring hanger bushings out of the mounts on the frame? They are the screw in type. The truck is a 58 3/4 ton. This is on the front. I know you press the ones out of the springs. Thank you johnj
john j
#35249 05/13/2003 8:07 AM
The same way they come out of the springs. Unfortunately, it's hard to get a press on them, so you have to come up with another solution to press or pull them out.
Paint & Body Shop moderator
