| | | Forums66 Topics128,052 Posts1,055,726 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35248 05/13/2003 1:34 AM | Joined: Jan 2002 Posts: 12 Member | | Member Joined: Jan 2002 Posts: 12 | Ok how do you get the spring hanger bushings out of the mounts on the frame? They are the screw in type. The truck is a 58 3/4 ton. This is on the front. I know you press the ones out of the springs. Thank you johnj
john j
#35249 05/13/2003 8:07 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The same way they come out of the springs. Unfortunately, it's hard to get a press on them, so you have to come up with another solution to press or pull them out.
